Phone won't connect to OBDLink LX device via bluetooth
jprates
Hi all, Somewhere along the last updates something has broken the bluetooth connection to my OBDLink LX device (car OBDII scanner). It was working fine on all apps, namely OBDLink, TorquePro and Hybrid Assistant, now it pairs but won't communicate data. I've successfully paired the OBDLink LX device to my laptop and used the Windows tool without problems, so I know the dongle is working fine, this is an Android issue of some sort. Before anyone asks, I've tried to reset, connect/disconnect the dongle, unpair/pair again, all to no avail. My phone says it is using the latest software version, which currently is: Andoid 7.0 Security patch 2017-Feb-01 kernel 3.18.31-perf-g6ca3aed-02969-g71aee3f Fri Jan 20 14:17:05 2017 build 39.2.A.0.417 Is there some kind of debug mode I can enter to help provide Sony the necessary logs to fix this? I'm obviously available to help, I need the bluetooth functionality working as supposed to. Thanks in advance. -jprates
1 REPLY 1
jprates
Anyone?
