Notification light and sound does not work when incoming mail or msg
Roni1
Experiazx
2 REPLIES 2
profile.country.RO.title
_alexdon_
@Roni1 Have you somehow enabled do not disturb mode? Press volume button and select end now.
alexdon
Jonas
Master
Hi @Roni1, welcome to our community!
I'm sorry to hear about that. Slightly_frowning_Face
Are other sounds working in your phone, for example when you receive a call or a notification from an application?
Please make sure that do not disturb is activated like @alexdon recommended. This will disable all sounds in your phone.
I would recommend checking that these applications are not blocked, if they are you will not receive notifications from them.
Go to Settings > Notifications > find the app(s) > tap on it and check if "Block all" is activated.
You can also reboot your phone in safe mode, ask someone to send you an email or a text message and see if you can hear the notification sound.
Let us know how it went! Slightly_smiling_Face
