How to turn off clik and vibration on xz
MiniGrim
Can't find the option to turn of the clicking sound an vibration.
Jonas
Master
Hi @MiniGrim,
Do I understand correctly that you want to turn off the click sound and the vibration when tapping on the home button and so forth?
If that is what you want to do, go to Settings > Sound > Other sounds and turn off the sounds/vibrations you don't want.
Let me know if that helps, and sorry if I misunderstood your question! Slightly_smiling_Face
1 REPLY 1
Jonas
Master
Hi @MiniGrim,
