how to screen recording?
hydralisk
as title stated, how do i do screen recording with my xz?
6 REPLIES 6
profile.country.PH.title
MarlonUk1
unfortunately he native screen recording is not available anymore, you need to download one at Google Play Store, I recommend AZ recorder
hydralisk
aww, ok thx
Lord_viridis
I use "screen recorder 5+"
Loads of options for finetuning output
SDR1970
Contributor
I could with my Z5, is it not the case with the XZ?
Young1neil
Where is the screen record function on the xz?
Lord_viridis
It was removed from Xperia X onwards, you can find alternative options on the play store
