I am getting barely 2.5 hours on screen time with the Xperia XA. I'm not doing anything stupid like leaving it on max brightness (it's auto) and I don't run masses of apps - in fact as you can see from the screen grabs it is clearly the display which is the main culprit.
How on earth is this supposed to reach the advertised 2 days battery life? By not using it? It's absolutely useless.... very unhappy, particularly because it is otherwise a rather nice little device with that edge-to-edge screen.
Have I got a dodgy battery?!
@gtxshreyasxyz wrote:
I did a factory reset, and it worked wonders...
With wifi and mobile data turned off, the device only burned through 6% of the battery overnight
With wi fi and data off is like in aero mode. It is normal that the battery consumption is low (also without factory reset).
Sir, What is your XA's Screen-on time with mixed usage (FB, Whatsapp, Audio/Video etc.)
Why so serious? 🙂 You read me wrong. I told you, that you're lucky man. Your xa works fine, so you're not faced too much with its battery issue. That's why you don't know how bad it could be.
So I am not realy impressed with it. "Could be a bit better" Sony Xperia
still no update.... .73 has been out nearly a week was really hoping it'd push to the other models by now. With Wifi draining battery so extensively even with scanning disabled, I can't make it from morning to night...
Will factory reset fix battery draining issue?
