I have a newly bought Xperia XA (Titanium Black - just what I call the color) and I am experiencing a heating issue as well when:
Other than heating issue, I am also experiencing a battery issue (probably) because within an hour, even without using, the battery drops to 90%
Regarding the heating issue, this what happens.
The unit is bought here in the Philippines, I also updated my phone and is now on Build Number: 33.2.A.4.70
I saw there's a new update based from this link
/t5/Xperia-XA-XA-Ultra/xperia-XA-massive-battery-drain/td-p/1138332
How can I update mine? I don't see any notifications regarding the 33.2.A.3.81 update and I believe my phone needs this update as well because the first time I saw this on store, I fell in love with it and want it to be my primary phone.
Kind Regards and more power to Xperia team
I forgot to add. My Xperia model is
Xperia XA F3115
Your current build number is higher than the one you're asking about, and it's already the latest available at the moment.
It's normal to experience heat and battery drain during the first couple of days, system apps are optimizing and you also applied an update which will also consume some resources to optimize. Just observe it for one or two more days and things should settle down by then.
Also note that continuous usage of mobile data and camera would cause any mobile phone to heat up, but not to the extent of overheating and shutting down.
@Quester
Thanks for pointing out the build number. You are correct, I have the latest build.
I do not use the mobile data continously, only when traveling.
Can you suggest a good application that can manage application especially disabling/enabling Start Up Applications? Also an app that can optimize memory. I do not like those apps the automatically optimize the memory, I like to do it manually.
Honestly, I don't like memory optimizers and cleaner apps, they will cause harm more than benefit in most cases. If you go to Settings -> Memory & Storage -> there you can find a stock smart optimizer made newly by Sony that should take care of memory usage and free unnecessary occupied space.
