Hello guys , i am new here on xperia xa can move app and data to sd card ?
Thanks
That's how google designed this option, SD cards are not reliable, low quality ones especially.
Sony Xperia XA Ultra phones apps out of space internal storage
How can nmove apps to SD cards ?
need help
settings>apps>(select app)>storage>move to sd
remember , due to google's implementation of memory on android devices. apps that moved to sd card will still have parts of it on the internal memory. not unless you root your device, this can't be fully transfferd to sd card./
try to review your apps, and delete apps that you are not using frequently. move media (images, videos and music to sdcard), restart your device at least 2-3 times a week.
I have downloaded and install Bully with 2.81Gb and tranfer it to 16Gb SD card but all the file of the app still in internal storage still reserve space in internal storage even it said "App on SD card: 2.79Gb"!
hi
I have bought xa ultra and installed various apps.
I moved those apps to sd card, expecting the media downloaded by app will be saved in sd card.
But the media I download is getting saved in internal storage instead of sd card.
What has to be done so that data also gets saved in sd card?
