How to add widget to PIN lock screen
Chinche
Is there any way to add the clock widget to the PIN lock screen? I would like to see the PIN lock screen at the same time i see the clock everytime i screen on the phone. Thank you!
Jonas
Master
Hi @Chinche, welcome to our community!
I'm afraid that there is no setting to have the clock shown on the same screen where you enter your PIN-code. You can only have it shown on the initial lock screen that appears when you press the power button on your phone.
I can see how this can useful so I will make sure to forward this as user feedback! Slightly_smiling_Face
Let me know if there is anything else I can assist you with and have a great weekend!
1 REPLY 1
Jonas
Master
