Hi, can anyone explain why you can't get skygo on the Xperia z tablet
Thanks in anticipation
Sky has a tablet version of their app here: https://play.google.com/store/apps/details?id=com.bskyb.skygotablet but i can't test it as it's not available in my country.
If you're unable to download this app i suggest that you contact their support for assistance: apps@bskyb.com
Hi
Downloaded the skygo tablet app from playstore, says device incompatible for tablet
i downloaded it anyway and it works, no problem. Best d/l from playstore on pc, not tablet itself.
Just to let everyone know you can get skygo on the Xperia Z tablet now, it never worked before for me but it does now
