Headphone Port Cover ?
TH3ORY1
Hi i just opened my headphone port to plug in headphones and long at the cover it's got no rubber seal ? Can some one please check there cover on the Tablet z if the headphone cover has a rubber seal ? As my SD card and micro sim card cover has a rubber seal running al the way round it ? Thanks
<script charset="UTF-8" type="application/javascript" src="chrome://hdv/content/hdv.js"></script>
cyapalmos
Mine doesn't have a seal around the edge of the cover like the others, just a plug for the headphone hole. If that makes sense...
3 REPLIES 3
cyapalmos
TH3ORY1
Thanks I totally understand what you mean mine is exactly the same....
H4rry
Unlike the card ports on the tablet the headphone jack scoket is probably sealed so any water cannot enter the tablet.
