wh1000 xm4 not charging
I have a pair of wh1000 xm4 headphones that i have had for just over 6 months but when i try to charge them the red light comes on for about 5 seconds before going off. I have tried reinitialising headphones but it didnt change anything. anyone know if and how i could fix this.
1 REPLY 1
jumpsuit
Hi @primarkhoodie  and welcome to the Community :slight_smile:
When you tried to reset the headphones did the indicator light flash
blue 4 times at the end to confirm the reset has been completed?
Also have you tried a different cable?
If the reset was completed and the cable isn't an issue then its probably best you contact Sony Sony Support about this.
Details are Here
