WH-1000XM4 - Music scrambled when microphone is activated
profile.country.US.title
wengelin
Hi
I recently bought a pair of WH-1000XM4 Bluetooth noise-canceling headphones. When I try to play music and use the microphone at the same time the music sounds terrible, scrambled and far in the background. Is this expected behavior? Can I do anything about it? I want to be able to listen to music while waiting for others to join video meetings for example.
Best regards
AW
7 REPLIES 7
Anonymous
Hi Wengelin,
Can you mention are you using software on smartphone or laptop? did you try any other software?
wengelin
Hi!
This occurs on my computer (Mac). The music typically comes from Spotify but I have tested Youtube to verify, with same result. Meetings are either Teams or Google Meets through Chrome or Safari. Seems to not matter what combination of music/music, it's always the same. The behaviour seems to be: if microphone is enabled, any sound from an application that is not the one using the microphone gets scrambled.
HannahEd01
Hey wengelin, does the same issue happen on your phone?
wengelin
Hi
I just tried it with the combination Spotify + Google Meets (app) on my iPhone 13, and yes. The same phenomenon occurs.
HannahEd01
Hi wengelin, are you are streaming music and using google meets app through the same device at the same time or for example you have google meets on your MAC and streaming Spotify through your phone.
If you are using both on the same device at the same time I think this is normal and there is actually no issue here.
wengelin
Thank you @HannahEd01 , I've started to suspect that this might be the case. It's sad since I spend quite a bit of time in meetings, waiting for others to join. Music makes the waiting less dull. Thanks for helping!
HannahEd01
Hey wengelin, it's my pleasure to help! Thanks to you.
