WF-1000XM4 NOISE CANCELLING
Chris1603
Been using the new earbuds with ANC and have to report I'm disappointed with the ANC performance. I've done the insert dance and upgraded firmware to v1.15 but to no avail. On the tube this morning it was ridiculous - barely hitting any of the high noise at all. Compared to my Airpods Pro there is no comparison ... the Airpods are far better. I cannot work out what the issue is. Only the low level hum of everyday life is cancelled out. Tried other foam inserts too. The ANC works, but barely works. Also fiddled with the app settings without luck too.
11 REPLIES 11
dnicuk
Hi, do you remove the comply foams when charging or do they fit in the charger?
Which type of cancer moly are you using.
Thanks
David
KillingJoke1
