WF-1000XM3 creaking
profile.country.RO.title
ProDyx
WF-1000XM3 creaking
Hi!
I just want to know if it's normal for my new WF-1000XM3 to be creaking when I apply a little bit of pressure on top of them? Also, one earbud is creaking more than the other.
Any help would be much appreciated!
3 REPLIES 3
IamNic
Hello @ProDyx,
what do you mean by "apply pressure on top of them"? WF-1000Xm3 are the earbuds, aren't they?
How would you apply pressure on top of them?
- Nic
ProDyx
When I slightly press on it, like when I pick it up, a creaking can be heard, but only when I press on top of it(exactly where the SONY logo is).
And yes, I have the earbuds.
Joe_Dohn
Specialist
You shouldn't be applying pressure to them, I wouldn't know whether the amount of creaking is normal or not, but I wouldn't think anything of it unless the operation is affected or if it started creaking after being dropped or something like that.
