Songs are out of order on walkman
Songs are in the correct order on the software. They are not in the right order on my Walkman. I checked the properties on the software and on the Walkman. The songs are labeled with the correct number. This is only on a few albums. I don't know how to fix this. Any help?
Thanks.
Hi there,
Which model do you have?
Best wishes,
M
NW-A55
I've just found these suggestions in the help guide of the Walkman which mention using playlists or bookmarks. Here's the link: https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0002342858.html
Dude, if you, or anyone has this problem, the solution is to go to Device Settings and in Reset/Format list do Rebuild Database. It seems to be different than rebuilding the database after we turn the player on - this one took longer and in the end it arranged all the files in the right order. I did it with my Walkman connected to a computer via USB, but it should also work on its own.
