NWZ-S639F battery query
vigeon
Hi. Newbie here. Does anyone know where i can get a genuine battery for a Sony NWZ-S639F mp3 player? All the copies i have used are just a tad too thick making it impossible to secure the back on properly...
8 REPLIES 8
HannahEd01
@vigeon, that should be by sending it to Sony's service centre. Where are you based? UK?
vigeon
Am in UK. I think i discounted sending it to Sony possibly due to cost or age of the device. It's a 2008 Mp3. Sony directed me to a company called EET but they are not responding.
jumpsuit
Hi @vigeon
Yes, EET were the best people to try as they are the official retailer for Sony parts.
I've just tried to contact them too though without any luck.
HannahEd01
Hi vigeon and jumpsuit, what are you using to contact EET? I found this article about dealing with them: https://www.sony.co.uk/electronics/support/articles/00238906
They actually have a phone number 0333 241 9 251, as well as an email:
info@eet.co.uk
vigeon
Still waiting for some news from EET. This is taking ages, All i want is a battery that fits!
HannahEd01
Hey vigeon, did you call them? What was their response?
vigeon
After being told that someone would find out if they had any proper fitting batteries ive heard nothing for many weeks. Given up with them. Currently investigating https://www.lipolbattery.com/Ultra-Thin-LiPo-Battery.html while using an ill fitting Cameron Sino battery.
Anonymous
Yea that really is annoying, hopefully you hear from them regarding the battery soon and can actually replace it.
