victim311
MZ N510
Simple question but I cannot negotiate the Sony website to pose this question so I thought I'd try this forum.
I recently bought a portable minidisc player/recorder MZ N510 without an AC mains charger. It seems that I need one of these in order to record stuff. The nearest thing I have been able to source is a charger for a Sony minidisc player
AC-ES305. It has all the specs in terms of input/output voltage, polarity etc but I am unsure if the small plug will fit my model. The seller doesn't know. Can anyone advise, please?
Usually the plus should fit since the size is related to the voltage of the power supply.
Please try carefully to insert the plug.
Peter
2 REPLIES 2
Peter
victim311
Sounds good to me. Thank you, Peter.
