I can receive Traffic Alerts on FM radio when tuned into local BBC station; but when listening to DAB. source TA does not cut into broadcast as it should; could this be a weak signal issue or is it an equipment problem. I have reset radio and set ALL settings properly, any suggestions please
Hey theavenger, I don't think this is related to the car system, what you get or don't get on the Radio isn't relevant to the device itself, maybe try contacting the broadcaster?
I think it must be the device as TA interrupts the FM;CD player and Bluetooth players; I have contacted Sony Support and they confirm TA alerts on FM radio should interrupt DAB transmissions, as stated in the operating manual. Thanks anyway.
Oh cool! Did not know that XD, but at least now you know why it's happening, cheers mate.
