Has anyone found gaps between tracks while using Music for PC? I transferred Mike Oldfield's Tubular Bells 2003 to my Walkman in AAC format at 256 kbps using the Sony program, from the CD. But on listening to it, there are short gaps between tracks, but continuous music on the CD. I thought the Sony program produced gapless music? Or is that only with Media Go? Gaps ruin the music.
Have you tried creating the gapless tracks elsewhere then transferring them using Music for PC?
Also, what Walkman model do you have? Maybe it has it's own gapless playback switch (I used to have a player with this setting, wasn't a Sony one though).
- JD
I've used both Music for PC and Media Go. I believe the former is more recent than the latter. I'm only having the problem recently, so I'm guessing it is the more recent progam causing the problem.
I use a Walkman NWZ-A15.
