profile.country.BG.title
zamunda68
Fast charging
Hello guys.
I own WH-1000XM4.
I do have 33W (Xiaomi) and 61W (Apple) chargers which I use to charge my Mac and Xiaomi smartphone.
How much do I damage the battery of my headphones when I charge them with either of the fast chargers?
1 REPLY 1
Joe_Dohn
Specialist
According to the Help Guide, you should be okay as long as the batteries are not overheating beyond the limit shown. It only lists a minimum output current of 1.5 A and no specific mention of V or W specs, so I think you'd be okay.
You can try using the Xiaomi one and monitor the charging of the headphones to see if it causes an issue, if not then you know you can use that and then do the same with the Apple charger if you feel like you need a faster charge.
Hope this helps!
- JD
