i have lap sony vaio model>> pcg-61711w >>vpcca ..... i have installed windows 8 pro 64 bit but the catalyst conrol center didnt detect th amd driver and the switchable graphics is not working well it didn`t switch between the two drives ic control the intel only ??? what can i do plzzz
Hi wikaazz and welcome.
Which Windows 8 AMD Driver have you installed?
You could try installing Version 9.1 which is Windows 8 compatible. I don't know it if will fix your problem but it is worth a try.
You don't give your full model type so I can't give you a direct link but you will see the Version 9.1.9.1.0.0 under the Windows 8 Recent Downloads for the VPCCA3C5E available here:
http://www.sony.co.uk/support/en/product/VPCCA3C5E/updates
This driver is available from Vaio Update - do you have this installed?
