Touch screen is getting several touches, or is it Clickpad?
As a workaround I have to disable it.
1 WinLogo+x
2 devicemanager
3 HID- touchscreen, disable devise/(or enable if needed). Yes.
4 Restart not noneed
The other issue is in display, it has lines, or even black screens. Time to time.
I have not figured what the reason is.
External display is working fine with HDMI-cable.
Any ideas what can be done? What is the root issue?
Hi Jack,
It would be best to get in touch with the support team for help with this issue.
Best wishes,
Sean Mc
