I can not download Microsoft Silverlight. I use Norton 360. The computer uses Windows 8. Any hints ?
Hi Happyuser and welcome.
Which vaio model do you have?
If you bought the Vaio with Windows 8 pre-installed, try running the McAfee Consumer Product Removal tool (MCPR) as this was probably preinstalled and, unless totally removed, conflicts with Norton to block some downloads.
http://service.mcafee.com/FAQDocument.aspx?id=TS101331
