Excuse me if my English is not good, because i'm french! I don't know if i'm in the goor part of this forum to post this text! I have a Sony PCG-FR315S but my Sony reinstalation disk is KO! I can't do anything to install software wich are only in the DVD.
If someone has a solution i'm will be happy to know how.
Thank you very much
Hi onlyone and welcome to Club Vaio.
If you have the Sony Recovery Disc, you can try copying it on another computer - this sometimes helps.
If that doesn't work, you will need to contact Sony Vaio-Link Support and buy replacement discs.
You don't say what the problem is so I don't know if there is any alternative way ahead.
Press F10 on bootup if you want to do a full recovery
Appuyer sur F10 si tu veut faire un restoration complet.
Tahnk you for all the solutions proposed here, but my recovery DVD is dead. When i try to restore a software it take long time and finally it ends with a code error: 31.
I try to make a copy but it failed during the process and vaio link suppport can just answer by phone and i have not enough money to speak for the same answer.
Have you tried eSupport?
Avez-vous essayer eSupport?
Hi Onlyone,
You can contact Vaio-Link free-of-charge via e-support . E-Support is a self-service option available for registered VAIO-customers..
