profile.country.GR.title
bewareofGR
tv hdr problem
I own the 43xe7005
hdr on pc works fine because you can choose the rec 2020 color and picture looks as intended
on ps4, youtube, netflix the hdr color is wrong cause u can't select from the tv the correct color.
please update the tv so that we can choose the correct color setting like you have on the other tvs.
I will post 1000 comments until you do it, we bought a tv and we want to use it as intended, make an color option with an update so we can use it as you advertised.
Thank you
2 REPLIES 2
LightFoot
Specialist
Hi @bewareofGR
Sorry this is a user community (not Sony). If you want to contact Sony please contact Sony Support for your country or region. In the UK it is Sony UK Support
bewareofGR
Thanks m8 but I already know that no one from sony will answer or fix this problem.
Typical sony
