salmoliv
SONY W8 and display
I have a NAS where I have ripped my daughter's DVDs.
And I have other videos there.
I find it extremly difficult to browse the videos as it is.
Is there an option to display the videos by folder?
Thanks
Tags (2)
1 REPLY 1
Anonymous
Hi there
Im assuming your referring to the 2014 W8.
So when you are in the TV's media player and have displayed the folders/files.  Press the [Options] button on the remote control and choose 'Folder View'
undefined
Once done, press the [Options] button on the remote control again, and choose "Filename A-Z Down arrow"
undefined
You can also use a program called Serviio that runs from a PC/Laptop that can display your media content via folders on the TV.  This program can also convert your media files to a format that your TV can recognise, if it doesnt recognise it before hand.
Hope this helps.
