sony bravia KD-49ex793
ben706
Recently experienced slight flickering on right hand of screen, it started off with a horizontal line at the very top of the  screen barely noticeable, flickering occurs then goes back to normal for a few seconds and then flickers again with very faint horizontal lines throughout screen, replaced T-con board but still flickering does anybody have the same issue?
the tv is still watchable and very use-able
1 REPLY 1
Piscie
Hey @ben706, does the flicker happen with everything or specific contents only? Here are the things you can try:
-Make sure your TV is up to date
-Reset the TV to factory settings (settings -customer support - factory settings)
Hopefully everything will be okay afterwards :slight_smile:
