Simple IP control bug
Not sure if there's an official place to log bugs - there should be!
Simple IP remote control - not the complex XML-RPC variety, but the simple fixed 24 character variety, as defined by the document "Sony Simple IP Control Protocol for BRAVIA", most easily found here: https://pro-bravia.sony.net/develop/integrate/ip-control/
I have a KDL-40W705 and the protocol works for the most part - with a few quirks.
The largest issue so far is that TV channel selection is broken, the command "setChannel", which corresponds to *SCCHNNXXXXXXXX.XXXXXXX is OK if you give it channel 1 (*SCCHNN00000001.0000000), but give it anything above about 55, e.g. *SCCHNN00000057.0000000 and it replies ACHNNNNNNNNNNNNNNNNNN, AKA "No such channel".
Manually select that channel on the IR remote and it will NOTIFY you with message *SNCHNN00000057.0000000, so it knows the channel exists alright. This wouldn't be a problem if most channels were low numbers but what about HD channels BBC1 HD etc, i.e numbers 101, 102 etc ? No HD channels are directly selectable! I tried various numbers like 1.01, 10.1 etc in case of documentation bugs, and still no joy.
SONY : A fix to the firmware and a tad wore testing would be a great idea !
Thanks
Hi there, I would advise you to contact Sony's technical support team about this. Contact info can be found here.
I have done, thanks.
