Its driving me mad i still cant get any sound from the sony bravia KDL- 40EX524 when i connect the red and white leads from the back of the tv to the in on my pioneer hi fi using the DAT/VIDEO INPUT in connectors, please see attachments, i have set the sound settings as advised:
- Press “Home” on the remote commander.
- Navigate to “Settings” from the bottom list.
- Choose “Sound”
- Navigate to “Speakers” and press “Enter”
- Please make sure it is set to “Audio system”
In addition, this issue might be related to settings related to the digital audio output. Please check the following settings
- Choose “Sound”
- Navigate to “Digital Audio out” and press “Enter”
- Please make sure it is set to “Auto” or “PCM” according to the following link:
but still nothing happens only a buzzing noise , can anyone help???
hehe sorry to say that but...it's normal!
From the blurry pic, I can tell that you are connecting the componant audio RCA in to the audio RCA video in of your amp. You wil never get any sound.
You have to use the audio out of the TV that is a minijack input on your TV. So you need a minijack to RCA stereo cable.
in the top left hand corner of picture 2 there is what appears to be a Digital optical input covered with a plastic plug. suggest a Digital Optical cable from your tv to your Pioneer and using same settings for speakers to Audio system and selecting the appropriate input on the Amp should work.
