richard2650
KDL 32WD752
Our Sony is less than two years ago and it has started switching itself off at random times and then restarting. It also frequently will not respond to the remote where the only cure is to unplug the power and then replug.  The sleep and power saver settings are OFF
4 REPLIES 4
Pascale_F
Moderator
Hi Richard,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Richard2650,
That's very strange. Is the software of your TV up to date?
Cheers,
The_Black_Rose
richard2650
I think it updates automatically
The_Black_Rose
Specialist
Hi Richard2650,
Could you try resetting the TV? Press on Home - Settings - Customer support - Factory settings.
Cheers,
The_Black_Rose
