IPlayer Problem on KDL 40EX503
I keep getting the message the Temporarily Cannot Access the Server Try Again things were fine last week wqith the problem starting on Sunday. I've tested the ethernet connections, rebooted the router, checked the network via the TV all appear OK. The TV is connected to a Sony Home Theatre system and I've tried the tests with Theatre switched on and off. Any other suggestions of other action I can take would be appreciated.
1 REPLY 1
Anonymous
Hi there
Unfortunately this is a known issue, which there are currently no updates of a resolution thus far.  Please see the main thread below, as any updates will be posted their.
https://community.sony.co.uk/t5/televisions/nov-2015-bbc-iplayer-temporarily-cannot-access-the-serve...
