On my KDL-42W829 I get the following error when I try to play a video from browser.
"Too much memory required to display this page"
It does not happen immidiatly. If you play the video and keep watching for 10-15 minutes, all of sudden video will be stopped and you will get this page.
Is it a known issue with Sony or just with my TV?
Thanks
Your welcome.
Remember the audio when connecting though vga>hdmi cables. If you havnt purchased it already, you need to read carefully the description as many of them are HDMI > VGA (ie TV to PC and not PC to TV)
The reviews of this one seem pretty good:
http://www.amazon.co.uk/Neet%C2%AE-Converter-Supports-Computer-Lifetime/dp/B002C6NP5C/
Hi there
This is normal. The web-browser is not a substitute to a computer. Even though some videos may play (HTML5) the TV does not have the memory capacity - therefore you get this error. It will be the same for graphic intensive web-pages too.
Unfortunately this cannot be fixed, due to the fact that you are trying to do something that the TV was not designed for.
Thanks for your reply, seems a reasonable answer. I was wondering how it is buffering Netflix and Youtube if it does not have enough memory to buffer through browser.
But alternatively, I will connect TV with Laptop to play videos using browser. Hopefully it will connect successfully using VGA to HDMI convertor cable.
thanks
Your welcome.
I am facing same issue while streaming a video on youtube. Can some one please help me with the solution.
Hi chery123, what model do you own? Does the issue happen on other apps as well?
