It does seem indeed strange.
Other than a full factory reset, I don't have any other suggestions to be honest.
Is Google faffing around with their system? At least you have a search page anyway, and arguably the startpage is better, purely on privacy reasons - but doesnt have the same ring as "googling the answer"
Im not familiar with this exact model tv, however if you can explain whats wrong with the picture quality, maybe there are some settings to adjust that may help.
Have you adjusted any picture settings yet?
I honestly "strongly" recommend getting rid of the SCART cable - take the plunge and go to HDMI, you will not be disappointed !!
It is possible to reset the picture settings, press the [Options] button on the remote control, goto picture settings and theres an option to "reset" it.
Also the "Scene Select" may have been adjusted accidently as well, see link below:
http://pdf.crse.com/manuals/13LW600114/EN/c_aadjust_scene.html
If its not the picture settings, and you are not sure what settings were adjusted, a factory reset it the way to go.
One of the settings that I recommend that you turn OFF is the Light-sensor in ECO settings. See link for instructions:
http://pdf.crse.com/manuals/13LW600114/EN/c_aadjust_lsensor.html
Hopefully this helps!
Brilliant - well done to Virgin for that. If only TalkTalk would send me a new router as easy as that, I would be happy, but its like pulling teeth.
You are welcome by the way, happy to try and help
