can anyone please explain to me why is there no dropdown menu for xperia e16i commonly known as w8
download this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
and after downloading u'll see that it supports all SE phones
Can you please elaborate in a bit more detail what you mean. ie Can you give a specific example?
i think hez asking of the notification drop down menu..
i mean here in the SE site ... no w8 selection ... how can i update my phone now ?? i checked and said that i need to download it here
theres no even sign of w8 in this site ...
what if you select X8 instead of W8? (there are pretty much the same phones)
you sure its just fine to update my W8 using the update of X8?
download this..
thanks for the help ... it means a lot !
hmm
