Just bought the phone, in Sweden,. Has already done one update. But I only have the inernational keyboardd and as options chinese and japanese. But because I´m swedish I of course expect option Swedish keyboard.
open a conversation -> tap on the white input box -> tap on the wrench -> tap on Portrait keyboard -> Full keyboard
go to
messaging -> tap on the white input rectangle -> on the bottom right look for a wrench -> tap it -> writting languages -> select the language or languages that you want/need
btw you should update to 2.3.4 it's quite awesome
use Update Service or PC Companion to update your phone
if the update it's not available on your network/country you can manually update your phone
Still only have english,chinese or japanese to choose. I have swedish in my languagesetting
I already have this version. But still no swedish keyboard. I guess I´ll go back to shop tomorrow and complain. If no cure there will be an Iphone instead. Very disappointed at Sony. I thought they could o better. Selling a phone in Sweden without swedish keyboard Not good.
are you sure?
Yes I´m sure. I have found the wrench but no globe. When i tap it i still get those f-n chinese and japanese and international keyboards.
swich to landscape mode
go to the wrench -> tap on Portrait keyboard -> Full keyboard
since the Phonepad doesn't support other language besides english, japanese and chinese
if you must have a T9/phonepad keyboard try this
EvenBetter NumberPad Keyboard
https://market.android.com/details?id=net.fredricknet.inputmethod.latin&feature=search_result
