I can't find the photos i click in my memory card. where do the photos get saved? how do i get them transferred to my phone?.
As well as where do the new contacts get saved? they don't get saved in the sim.. please help..
- shriprada
they will be in a folder named DCIM > Andro..
and u have to conect ur phone to ur pc and transfer them
theres no specific path for the contacts though..
why do u want to know the place.. /?
Hi, if you are referring to photos taken with your phone, those are saved in your SD Card. You can either view them using a File Manager (download it from Android Market) or from PC/Laptop (connect phone via USB Cable). Have a look at folder DCIM.
