What is the tree symbol at the left corner in my display (W715)?
Hi
Does anyone know what the tree symbol at the left corner in my display is (W715)?
It was all of a sudden there right beside the icon showing level of net connectivity and the icon "H" for 3G (to the right of these two).
Cheers, enzo
It looks something like this:
Dr_Chris
Champion
This is the Outdoors Profile setting, which you must have accidentally set.
If you go to: Main menu--Settings--General--Profiles--Here, change the Profile setting from Outdoors to Normal and the icon should disappear.
1 REPLY 1
Dr_Chris
Champion
