Since I have no wifi how do i access the internet through USB? I can't find any documentation on this.
It might not be possible, on your phone K850i. That option might not be available on your phone, let me see if i can check.
Go to: Main menu--Settings--Connectivity--USB--Advanced--Internet access--Via computer.Does your phone have this option?
If you replace advanced and internet with usb network yes
ok again thanks anyway
Thanks for your help, seems its not possible though
Lets check something, go here on your phone. Menu>Settings>Connectivity>USB>USB Network>USB Network Type>Via Computer. Let me know if your phone has that option.
yes it has that opyion and it is selected
http://developer.sonyericsson.com/cws/download/1/708/240/1260889918/96058-wp_k850_r3a.pd This is the white paper for the K850i & the K800.If you look on page 25 under USB Ethernet emulation: Connect to Internet via the phone (phone as modem for the PC) or the computer (the reverse,which is what you want to do)--this is ticked Yes for your phone, so it should be possible.
I've activated the via computer part and it still doesn't connect, any idea's?
