hi all,
i got the update notification for xperia x10 few days back, i quickily connected it to pc using pc companion and took the backup, then i started the update process, it reached till prepared, and after that it started initialization, but here the problem started. it was showing the initialization for 4 hours, i thought may be it hanged so i stopped it and disconnected the phone and restarted the update process, same thing happened this time. the progress bar doesnt show any progress after initialization, it showed 100% in initialization after some 4 hours but after tht nothing happened.
i dont knw the problem, it can't be network problem, as i have a 1mbps connection and i checked the speed also before starting the update,
i kept the update process as it is for 10 hours, but it still didnt show any progress from the last time.
is anyone else facing this problem?
Download a program called Sony Ericsson Update Service and see if that updates the phone for you.
YES! EXACTLY THE SAME ISSUE - NOTHING WILL DOWNLOAD TO MY PHONE. NOT NEW UPDATES - NOT REPAIRS - NOTHING! WANNA GO MAD!
try doing a factory reset both of you connect back to pc companion and try again from there or you can do an update via air....
yes, I also solved this problem using SEUS. It works from this software.
