anyone know of an effective way of removing them from the screen?
yes, it comes with a film to protect the touch sensor/digitizer. take a close look at the edges of your screen and you'll be able to see it.
most likely you only scratched the screen protector, you can always replace it.
Are you saying that my phone (X10i) comes with a removable film covering the screen?
uliwooly = genius
