Ray Update
51cem
Ray Update
Ok, so i've read the Post about what models will be supported in the Gingerbread update from here
http://blogs.sonyericsson.com/products/2011/09/26/new-gingerbread-software-available-in-nordic-count...
My Xperia Ray is model 1252-4844 which isn't listed Slightly_frowning_Face
Does anyone one know if i'd be able to apply the update mentioned in http://communities-origin.sonyericsson.com/thread/24433 ??
I was hoping to do the update to 2.3.4 but seeing my specific model isn't list i'm wondering if SE will be going back to their great support and updates that they did for the previous generation Angry_Face  (yes laced with sarcasm)
If anyone can shed any light on this it would be appreciated.
So far from reading the forums i've fixed all my niggles etc i've had with the phone.  It's been great.
KrazyD
Contributor
Hello,
The update rollout is planned for the Xperia ray. It is probably just not available for your region yet but keep checking as it will come available.
1 REPLY 1
KrazyD
Contributor
Hello,
