Problem with keys locking whilst in car cradle
Hello all
I have a simple car cradle that I use to view GPS whilst driving.  Unfortunately after few mins of driving, the three keys at the bottom lock up - touch screen and power buttons still respond but I cannot menu/home/undo with any of the three keys.  If I take the X10 out of the cradle - tilt it back to the level then the keys work again!
Could this be to do with the accelerometer sensing the car vibration in this mode and some 'shake' event in the configuration locking the keys???  If so is there some setting that allows to not lock the keys???
Anyone else have this problem or not?
SE - pls tell me what I'm doing wrong???
Thanks in advance - David  Thinking_Face
sushidushi
Contributor
Not sure that this will help, but could you turn off the accelerometer(Settings - Sound & display - Orientation) whilst you're using the cradle, to see if that makes a difference?
Or might it possibly be that the cradle is somehow pushing a button on the side of the phone and that is causing the problem?  If you haven't already done so, try using the GPS without using the cradle and see if the problem goes away.
9 REPLIES 9
sushidushi
Contributor
Thanks for that reply - yes it was the foam on the side of the cradle pushing the camera key! :smileygrin:
I also read in another post about locking keys that if the camera key is kept held down for too long then it tends to lock up the lower buttons!
David
Similar bottom 3 key locking problem.  Only way to unlock them and use the keys is to pull battery. Keys then work for two minutes and then lock up again.
are you using a protective case? if you are it might be too tight and it's causing your phone to act up
do you have android 2.3.3?
settings -> about phone -> android version? if you don't use
you can use Update Service or PC Companion
update service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
make sure you backup everything, don't rely on the backup & restore app
this is how
make sure you have the LATEST backup & restore app
Use one of these links to download the Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
there are some networks/countries that won't release the update, if your country/network is one of them
you can manualy update your phone
this is how
http://talk.sonyericsson.com/message/90716#90716
No tight case.  Currently no software loaded; thus Android version does not show up under "about phone".
I thought it was a software problem because it is always exactly 2 minutes after re-setting the battery that the keys lock up and don't function.
Now I can't get the wostware to reload.  Both Update and PC are not working.  Part of the problem is that I have to pull the battery in order to get use of the back key and thus go thorugh sequence of turning off phone, etc then re-plug while holding back key before bak key becomes non-functional.
What is the difference between setup 2.11.9.6 and other numbers like 2.11.713.exe?
Thanks,
that doesn't make sense, on you X10 go to settings -> about phone, scroll down and you'll see it
