My x10 mini has up until yesterday had no problems showing different calendars at a time.
But now it shows no calendars at all, except for Week Numbers. All days have the entry "All day: Week XX". I have tried:
- logging on to the Google Calendar from the laptop and turned Week Numbers off, but it stays on the phone.
- updating the phone
- synchronizing the phone/calendar
- turning auto-sync on and off
- clearing cache
- rebooting the phone multiple times
I have found solutions for other phones which include going to the calendar and pressing the menu-key. But nothing happens, so it appears the x10 mini does not have that function.
So my questions are:
What happened to the calendar?
What can I do to correct it?
I have searched this forum for answers as well, but have had no luck finding a solution for this problem. I really hope you can help me.
Thank you in advance.
make sure you sync your contacts with google
on your X10 open your calendar
press menu -> my calendars -> make sure google is selected
While a new calendar could help, I would prefer it if I got the native one to work.
As mentioned, I have already tried going to the native calendar and pressed Menu, but nothing happens. Regrettably, I don't think you have that function on an x10 mini.
Any other ideas?
Thank you for your help 🙂
do you have 1.6 or 2.1?
2.1-update1
http://www.sonyericsson.com/cws/download/1/861/459/1287562492/E10i__UG_EN_1238-6358_3.pdf
Page 54
Synchronising your calendar
If you have a Sony Ericsson account or a Google� account, you can also synchronise your
phone calendar with your web calendar. See Synchronising on page 58.
If you synchronise with Google Calendar� and have access to multiple shared calendars in
Google Calendar�, all appointments from all of the shared calendars will appear in the calendar
view of your phone.
Synchronising
Synchronising information between your phone and a computer is an easy and practical
way to share the same contacts, messages or calendar events on both devices. You can
use the applications in your phone to synchronise different information:
� Sony Ericsson Sync � synchronise your phone contacts with your personalised
Sony Ericsson website. The contacts are safely stored in one place and you can use them
with several phones.
� Google Sync� � synchronise your phone with your Gmail�, Google Calendar� and
Google� contacts.
� RoadSync� � synchronise your phone with your corporate Microsoft� Exchange email,
contacts and calendar to keep them with you all the time.
Sony Ericsson Sync
Use Sony Ericsson Sync to synchronise your phone contacts with a personalised
Sony Ericsson website at www.sonyericsson.com/user.
At this website you can safely store and edit your contacts in one place. With
Sony Ericsson Sync you can synchronise them with several phones or a new phone. You
need to have a Sony Ericsson account to use the website. See To set up a Sony Ericsson
account in your phone on page 58.
At the Sony Ericsson website www.sonyericsson.com/user you can also use your personal
information with different social media, for example, you can match your phone contacts with
your Facebook� friends.
To set up a Sony Ericsson account in your phone
1 From the Home screen, drag upwards.
2 Tap Settings > Accounts & sync > Add account > Sony Ericsson Sync.
3 Follow the registration wizard to create a Sony Ericsson account, or sign in if you
already have an account.
4 Tap Sync interval and select how often you want the phone to synchronise
automatically.
5 Tap Done.
To set up an existing Sony Ericsson account in your phone
2 Find and tap Settings > Accounts & sync > Sony Ericsson Sync.
3 Enter your username and password, then tap Log in.
4 If desired, change the default synchronisation settings. Tap Done.
To synchronise manually using Sony Ericsson Sync
3 Press .
4 Tap Sync now.
To set up a SyncML account using the Sony Ericsson Sync application
2 Find and tap Settings > Accounts & sync > Add account.
3 Tap SyncML
4 Tap the account, server address, username and password boxes and enter the
information required.
5 If desired, change the default synchronisation settings. Tap Done.
Contact your SyncML service provider for more information about your account settings.
To add a second account, tap in the account list view.
To edit your Sony Ericsson account
2 Find and tap Settings > Accounts & sync > Sony Ericsson Sync > Account
settings.
3 Tap and edit the desired information.
4 Tap Done.
To set a synchronisation interval
settings.
3 Tap Sync interval to set a synchronisation interval.
To remove a Sony Ericsson account from your phone
2 Tap Settings > Accounts & sync > Sony Ericsson Sync.
3 Tap Remove account.
The account is removed from your phone, but it still exists. You can use it to log in to the Sony
To stop synchronisation in Sony Ericsson Sync
� When synchronising, tap Cancel.
Google Sync� synchronisation service
You can use the Google Sync� synchronisation service to synchronise your phone with
your Gmail�, Google Calendar� and contacts.
To synchronise with your Google� account, the account needs to be set up in your phone. See
To set up automatic synchronisation in Google Sync� on page 59.
2 Tap Settings > Accounts & sync.
3 Mark the Background data checkbox.
4 Mark the Auto-sync checkbox.
5 Mark the checkboxes for the synchronisation items you want to synchronise
automatically.
6 Press .
7 Mark the checkbox to enable automatic synchronisation for Gmail� .
To synchronise manually with your Google� account
3 Tap the Google� account you want to synchronise.
4 Tap Sync now.
To stop synchronisation in Google Sync�
1 When synchronising, press .
2 Tap Cancel synca
so in other words, go to
settings -> accounts & sync -> make sure background data and auto-syn are selected, tap on Google -> make sure calendar is selected
Tried all that, unfortunately...
I am currently backing everything up. Might try a reboot of the Google account altogether.
That might do the trick, right?
