problem: screensaver always shows "new messages:2" even though all is read...
This started after upgrade to build 4.0.1.A.0.283
rebooted phone but it does not help
Anyone else seen this? How fix?
Annoying..
/Magnus
6 REPLIES 6
you can turn off your phone, take the battery out, press the power button and hold it for few seconds, put the battery back on and turn your phone on, check if the notification its gone
also go to
messaging -> MENU -> settings -> uncheck -> check notifications
you can backup your phone and then go to
messaging -> menu -> delete meessages/delete all
settings -> privacy -> settings reset
Use one of these links to download the Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
I did some random deletes of old messages and suddenly it was gone... but thanks for all suggestions!
anytime
slimshaddy
Hero
mark the thread as answered..
