Hope someone can help...new here...just got an Xperia X10 Pro. My wife sent me a picture message (MMS) message but it arrived just as a text with a web link. I had to log into the T-mobile website to see the picture instead of just being able to see it in the message on my phone. I can't find any setting on the phone to correct this. Any ideas welcomed thank you :-).
You need to get the settings from your service provider in this case Tmobile, to put the settings on the phone you go to
Menu>Settings>Wireless & Networks>Mobile Networks>Access Point Names < here you press the menu button to add a new one, put the info that you get from Tmobile and then you should be able to fully enjoy the MMS feature.
Thanks Josh. I thought the correct settings were already in but I went to the T-mobile website and got them to resend them to my phone and voila 🙂
