hi i need to set a passward for some application is this possible or not ???
Search the Market, to name a few free ones .... App Protector Lite and Smart App Protector (App lock).
Have fun.
thnx i really appreciate ur help i'll try one of these applications
Search around (the Market), there should be more. Find the best that you like, as you know, you can always uninstall them.:smileywink:
ok
Enjoy your 'hunt'
