![](/skins/images/12E123D1D0AC24EAD5F6BBAE7DE97773/responsive_peak/images/icon_anonymous_message.png)
Hello,
I have a X10 mini and having a few problems.
Could someone give me a good explanation on how to save pictures that I recieve in an MMS pic message? also then a good explanation ho to transfer the picture to my PC via bluetooth? I am struggling to get my phone to connect to my PC.
Glad to have been of assistance.
Don't worry about the Handcent sms thing, I edited that post almost immediately after I had posted the first cos I remembered that you needed Handcent for the pop up menu to work, so assume you were darn quick of the mark and were reading original whilst I was doing the edit.
Happy that you are now sorted!
I think I have finally cracked the bluetooth mystery and gave a detailed response on the following link. Hope it helps.
http://talk.sonyericsson.com/thread/4503?tstart=0
On the saving picture message front, download the app Handcent sms and that gives you the ability to save a photo message to sd card. Long press on the image and you should get a popup that gives you the option.
Hello suze.
Thanks for the reply, I have the bluetooth sort of working but it does seem more tempremental than other phones. I have to have "New Connection Wizard" open on my PC before the phone will connect to it where as other phones don't need anything open, they just seem to be able to wake the PC up automatically and send the file.
Picture message save though not working? I have tried long presses at various stages through out the messages and don't get any option to save just get a zoom in or out symbol.
New question: where is the message folder? e.g inbox / sent messages / reports etc? all I can find is the shortcut on the main screen which takes me just into recieved messages?
I bought an app called autosave mms, in fact it might have been free, which...auto saves photos!
If a long press does nothing, try pressing the 4squares button at the bottom of the screen. It will bring out an advance menu. You should be able to save it from there.
Just go to mediascape and choose the Photo tab and you should see the picture. If you are looking to access it through the PC, it is under the DCIM folder
Hello, Thanks for the replies.
Found the answer by browsing more topics.
http://talk.sonyericsson.com/message/1679
Free app called "handcent sms"
Suze did mention Handcent before.
Thanks darkmax for pointing that out, I had overlooked that as I didnt understand what it was.
Sorry suze and thanks for the help.
You're most welcome. Crdit must be given where it is due.
