One question about "ROOT" + "AutoKiller Memory"?
I just install the JuiceDefender and AutoKiller memory. Inside the AutoKiller Memory got setting for "Memory limits" value and other Advance setting tweak like SD card Spped up, Memory management tweak and many more.
Question is, my device is non-ROOT, if I adjust the "Memory limits" and other Advance tweak setting, then I uninstall the AutoKiller Memory apps then restart the device, the setting will restore back to Andorid default value?
Jake-SonyXperia
Champion
Based on the information I have available to me, any changes made by an application would be removed and defaults would be put back in place.
3 REPLIES 3
Jake-SonyXperia
Champion
Noted, Thank you Jake-SEanswers.
Jake-SonyXperia
Champion
Any time, happy to help.
