My xperia X10 refuses to boot! I notices it rebooting yesterday on it own, but it frooze at the point where sony erriccson shows before the purple wave. I removed the battery and tried starting and have had no luck since then.. all I get is the initial customary vibrating just before coming on... but it stops there.
pls what do I do?
If no luck, do a software repair using SE Update Service (hopefully it is a software issue). Here's the link for download, http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10?cc=gb&lc=...
Good luck.
Try pressing the centre button (HOME) together with the ON/OFF button.
Good luck.
Thanks.. but this didnt work...
it only flashed a red light from the led indicator...( although the flashing light was some sort of improvement!)
but it still aint coming on.
thanks once again... I hjave downloaded and installed the SE updater service.. but all I get on commecting the USB is a continuous flashing red light....
i am suspecting my battery might be faulty? is that a possibility?
You appear to have exactly the same problem as this post
http://talk.sonyericsson.com/message/62690#62690
It looks like the battery has died but you should be able to check that by going to a store and getting them to check it or try a new one
Thanks a lot... I had to change the battery.. it was totally dead.. but also I had to also use the update tool... lost all my information but luckily I had a back up on my SD card!
my phone is Alive now!!!!
have a great day
Great that you have 'revived' your phone! Enjoy ....
