my x8 phone isn't work
I charged the phone.
At one point, switch off the power, time passes ...
Later, wanted to see the time - does not respond to buttons.
I reconnect the battery, try to restart the phone.
It shows a red LED and nothing else.
seus does not update the phone.
what are the solutions to the problem?
upd
after my actions
now it shows SE Logo, but xrecovery is not loading
36 REPLIES 36
LED isn't blink when i try it
but phone try to boot
boot is not sucessful
gwhispererz
Champion
Remove battery, re-insert battery and try again!
gwhispererz
Champion
Just keep holding the back button for some time (while connected to PC/Laptop).
of course. the attempt number... over 9000
Yes, I'm doing.
I know these devices are basically.
I have been repairing phones before
gwhispererz
Champion
If all the above did not 'revive' the phone, it could be faulty phone usb connector or faulty usb cable.
when i try to connect phone to PC with USP
- LED is green
cable are working
usb in my pc are working
green led and pc companion/SEUS/SEUS Pro(USP) tell me about: phone usb are working
gwhispererz
Champion
Good! Can you power up phone then?
All my attempts to run the phone in the GUI unsuccessfuly.
